" /> WFM Statistic - AHT (or the like?) by Interaction type or call type - Genesys CTI User Forum
Author Topic: WFM Statistic - AHT (or the like?) by Interaction type or call type  (Read 2565 times)
Offline zimmerru
Our WFM group is asking whether we can somehow create a stat to use in WFM for AHT by Call Type, such as Credit Card vs General Inbound Queue or any of the other skills we use to deliver calls to agents.  We don't currently tag calls wit hthe skill but we can certainly do that if it would help in creating a statistic for WFM.  Any ideas?  I have read some on creating custom stats but I think this is a little more involved... however I could be wrong.
Offline Tambo
Re: WFM Statistic - AHT (or the like?) by Interaction type or call type
« Reply #1 on: October 20, 2015, 09:02:54 AM »
surely your skill in Genesys is mirrored in your WFM app ??
Offline msh
« Reply #2 on: October 20, 2015, 11:23:23 AM »
I am not sure what exactly your problem is.
If you do a statserver filter you can then in your activity use that filter on the AHT.
Offline zimmerru
« Reply #3 on: November 06, 2015, 07:11:18 PM »
[quote author=msh link=topic=9167.msg41249#msg41249 date=1445340203]
That could be all I need to do.  I haven't dug into custom stats in statserver before so perhaps all I'm missing is creating a stat for the specific interaction/call type and using that in WFM.  Will do some digging and see what I come up with.  The current AHT stat used in WFM is just the agents AHT overall and does not indicate or have a filter what the Interaction/call type is.
