" /> Composer 8.1.4 - dynamically change prompt "Interpret-As" - Genesys CTI User Forum
Author Topic: Composer 8.1.4 - dynamically change prompt "Interpret-As"  (Read 2302 times)
Offline ymattica
« on: September 26, 2016, 02:24:43 PM »
hi,
I'm Using a variable that can hold an http  path (  file.wav  ) or a text to recite...
Can I dynamically change "Interpret-As" of a prompt ??
Regards
Re: Composer 8.1.4 - dynamically change prompt "Interpret-As"
« Reply #1 on: September 26, 2016, 05:33:57 PM »
No but you can put the text as an alternative to the wav file in case it is not found. Just check the prompt block properties
Offline ymattica
« Reply #2 on: September 26, 2016, 05:53:37 PM »
It is not what I would do. The prompt has the 'type' -> 'Variable' and this variable may reference a file.wav or a text .... So the only way is to use a branch and send the flow to two different prompt. One with 'interpret-As' -> 'Audio' and one with 'interpret-As' -> 'Text' it based on the contents of the variable?  :'(
« Reply #3 on: September 26, 2016, 06:03:00 PM »
Or build your own prompt via VXML code. Use a backend for that.
